Guys, do not think I am discounting your information. I believe you, hence the questions. I will go buy some heavy "I" beam for the main rails (this will also make it easy to make a slide mount to adjust belt tension on the gen), and a couple of cross pieces to tie it together. Now, how about mounting the beams to railroad ties perpendicular to the main rails. Then bolt that to the concrete with some rubber in between. Will the wood act to dampen some vibrations, or just magnify the problems?
Balance... I know this thing will never be "smooth" as compared to race stuff. It has to be able to be improved upon, though. So, you think the 67 to 68% is where its at? (100% rotating, 67 to 68% reciprocating I assume you mean, or are we on different pages with the weiights?)
Thanks
Wags
