Hello Bablitz,
Your Lister ID plate decodes as follows-- The 1960 is the serial number within its production year. The SR is engine model, and 1 is number of cylinders. The remaining digits are added to 1950 to give the production year, therefore 1950 + 20 = 1970.
Following your query on the IF forum, and seeing your photo's, your engine is reverse rotation, (as most were). I see the coupling bolts on the flywheel, so you could pull it by drilling a plate (half inch thick or more), to fit over them, and with the big nut loosened, tighten the 3 nuts against it till it comes free, or jolt it with a hammer if it needs help. Good opportunity to change the shaft oil seal if there is any sign of leakage. If it is the brass and felt type, it can be replaced by a standard double lip seal.
Flywheel nut thread will be normal direction. Flywheel rotates clockwise as you view it. Regards, Combustor.
