Author Topic: Oil ring or set needed for 6/1 GM-90  (Read 5057 times)
Spark_Chaser
    • Web Page
« on: August 30, 2010, 09:08:24 AM »
Chipped one of my oil ring edges during dis-assembly for a move last year.
GM-90 6/1, Alloy piston, DI, uses 5 rings, same ring size 6/1 CS.
1 & 2 compression, 3 is a scraper, 4 & 5 oil rings (Chipped edge on 5)
Looking for a set or just the oil ring.
Spark_Chaser
6/1 GM90 disassembled and in work
past
5KW ST sold
Northern Lights 7KW sold
quickies
Re: Oil ring or set needed for 6/1 GM-90
« Reply #1 on: August 30, 2010, 02:31:07 PM »
Hi Spark Chaser,
I've got some four ring sets for the 6/1 (Std & 020) on my web site, which isn't
quite what you want and if only for the oil ring would be an expensive way of
getting one. Sorry I can't realy help, but hopefully somebody in the group will
have a spare they no longer need in some forgotten box of odds and ends.
Geoff
www.e-gaskets.co.uk
Spark_Chaser
    • Web Page
« Reply #2 on: August 31, 2010, 10:51:51 PM »
Geoff,
Thanks for the reply.
Figured that I might have to liberate the one oil ring from a STD set but would check here first.
Hastings makes a set available here in the US.
Central Maine Diesel also shows a listeroid set on their web site.
Have saved your web site for possible future needs.
S C
Spark_Chaser
past
5KW ST sold
listerparts_SEP
« Reply #3 on: September 26, 2010, 11:59:54 AM »
Hi,
I have the oil rings available separately. You can buy from here http://www.stationaryengineparts.com/Piston-ring-set-6-1-8-1-12-2-and-16-2...114.3mm.html
Make sure you see the drop down menu for the options available. I am happy to ship almost anywhere in the world, the websites checkout handles most locations ok.
Steve
apogee_man
« Reply #4 on: September 26, 2010, 05:01:08 PM »
If I were you, I'd hone the cylinder and install a new ring set.
Food for thought as it's already apart and the difference in $$$ and effort is minimal.
Steve
« Reply #5 on: September 27, 2010, 02:10:56 AM »
apogee_man's plan has my vote.
How many dollars are we talking about?
Casey
wrightkiller
« Reply #6 on: September 27, 2010, 12:51:02 PM »
Doug : Just hone the cylinder and install a new ring set.... and save the old ones for spares..   You will sleep better at night.. ;D ;D
Veggiefuel
  • Energy Machines Ltd.
« Reply #7 on: September 29, 2010, 03:57:09 AM »
I have GM90 rings in stock.
Go here and look in the parts section.
http://www.energymachines.ca/index.htm
email me if interested.
veggiefuel
