Lister Engine Forum
Welcome, Guest. Please login or register.
September 07, 2010, 10:16:17 AM
Login with username, password and session length
Search:     Advanced search
New Lister Engine Chatroom Added
http://listerengine.com/smf/chat/flashchat.php
Photo gallery - www.listerenginegallery.com.
61814 Posts in 5217 Topics by 2833 Members
Latest Member: impogigargo
* Home Help Search Login Register
+  Lister Engine Forum
|-+  Lister Engines
| |-+  Listeroid Engines
| | |-+  Lazy Governor - Any ideas ?
« previous next »
Pages: [1] Print
Author Topic: Lazy Governor - Any ideas ?  (Read 387 times)
Veggiefuel
Energy Machines Ltd.
Full Member
View Profile WWW Email
« on: July 29, 2010, 09:26:17 PM »
I have a governor on a GM90 which hunts back and forth regardless of the speed adjustment on the threaded rod.
Conditions:
- First smoke
- No cooling system yet
- No load (of course)
- Regular diesel Fuel
- Gov. linkage has been checked and seems to be free of any drag
http://www.youtube.com/watch?v=4FSxzbg9sJo
Anyone have any ideas on how to solve this ?
Thanks,
veggiefuel
Logged
tttonyyy
Newbie
View Profile
Re: Lazy Governor - Any ideas ?
« Reply #1 on: July 30, 2010, 08:11:22 AM »
If it's not the linkage it must be the governor itself... must be sticking?
Logged
toydiesel01
Newbie
View Profile Email
« Reply #2 on: July 30, 2010, 04:03:07 PM »
I had to change the spring and linkage set up to what utter power recomended for better governor response, but mine was not wandering
i would try cleaning the injector tip  and remove all linkage outside the engin and inspect for any burs or some parts that don't move freely --look at the yoke close to the pump above the adjustment. the little pin moves up and down and also has forces on the side .  Needs to be removed and a close inspection ,after be sure to lube it good
George did alot of research  on this .
also check all fuel lines and filter for blockage, check high psi line for very small leaks
hope this helps
Logged
Bottleveg
Full Member
View Profile
« Reply #3 on: July 30, 2010, 05:39:07 PM »
Wholesale painting is often a problem in the linkage area. I always clean the paint off the movement surfaces. I often find the yoke is stuck together with the stuff. Wondering sounds more like injector tip or fuel filter, as already said.
Logged
Hero Member
Mean and green
View Profile
« Reply #4 on: July 30, 2010, 06:27:54 PM »
Also make sure ALL the air is out of the system.
Logged
2005 Ashwamegh 6/1 #217 - ST5
bschwartz
Jr. Member
View Profile Email
« Reply #5 on: July 30, 2010, 07:36:41 PM »
It almost looks like the speed is set too slow, and the governor can't keep a steady pace.  If there is any way for you to check the speed, I'd look into that.  The governor is shutting off fuel at a very low throttle position.
Logged
-Brett
1980 240D, 1995 Suburban 6.5, Metro 6/1..... What else can I run on WVO?
Veggiefuel
Full Member
« Reply #6 on: July 30, 2010, 11:06:49 PM »
Thanks everyone.
bschwartz, your point has merit. I adjusted the speed up to 900 rpm (these engines can run between 750 and 900 with the correct flywheels) and the engine smoothed out.
Seems the engine may have a 900 rpm governor spring even though I ordered a 750. Huh
cheers,
veggiefuel
Logged
SHIPCHIEF
Hero Member
View Profile
« Reply #7 on: August 05, 2010, 07:06:00 PM »
The 'as supplied' springs are not any good. Too short. I quit diddling around with mine and followed the advise Toydiesel01 gave you. Check George of http://www.utterpower.com/problems.htm, and the governor problem: http://www.utterpower.com/problems.htm Repositioning the spring end bracket and finding other springs, which you get to test is real "Do It Yerselfer" stuff!!
Mine runs great now. But my first set of 'new' springs had the engine surging fast then slow, smoking big black gouts as it came up to speed, then closing the rack to coast down to a lower RPM and begin belching again.  Tongue
A little spring readjustment, maybe add or subtract a spring, then try again until you get it right.  Grin
« Last Edit: August 05, 2010, 07:48:33 PM by SHIPCHIEF » Logged
Ashwamegh 25/2 & ST12
Onan 6.5NH in an old Jeager Compressor trailer and a couple of CCK's
Pages: [1] Print
« previous next »
Jump to:
Sponsored by Outlaw Books
Powered by MySQL Powered by PHP Lister Engine Forum | Powered by SMF 1.0.9.
© 2001-2005, Lewis Media. All Rights Reserved.
Valid XHTML 1.0! Valid CSS!
