Author Topic: Need .030 oversize 8-1 alloy piston  (Read 3595 times)
rleonard
  • Mattoon, Illinois
« on: July 13, 2010, 02:39:14 PM »
A friend called today looking for this piston.  Anyone have one available?  As an alternative a new 8-1 cylinder and standard piston may work.
contaucreek
Re: Need .030 oversize 8-1 alloy piston
« Reply #1 on: July 14, 2010, 08:48:34 AM »
Did you try Lister-Petter themselves ? I have had luck with other CS parts.
rleonard
  • Mattoon, Illinois
« Reply #2 on: July 14, 2010, 11:59:18 AM »
Hi Paul,
They claimed that they were unable to get one through L-P.  Problem solved though.  They came up with a .040 o/s and will bore to fit.
contaucreek
« Reply #3 on: July 14, 2010, 11:36:53 PM »
To complete my 6/1 rebuild I need a cast piston and either need to bore or line the cylinder. Probably cut it bigger and sweat a liner into it and bore to keep with original piston dimensions.
