Author Topic: Wanted: Bearings for a Reduction Gearbox Lister STW  (Read 4615 times)
Warsashsteve
« on: March 30, 2010, 08:14:17 AM »
Bearings and bits wanted for the reduction gearbox in a Lister STW engine.
Parts & Part nos:
Roller Bearing 201-17630
Retaining Ring Bearing 201-14840
Joint for Gear Case End 201-22370
Thrust Bearing 201-22450
Circlip 201-22390
Roller Bearing Secondary Shaft 201-22400
Oil Seal (assembley back to back) 201-22420
Please keep in touch if you get get me any, or all, of the above.
Many thanks,
Steve
listard-jp2
Re: Wanted: Bearings for a Reduction Gearbox Lister STW
« Reply #1 on: October 14, 2010, 04:07:10 PM »
Most of the parts you mention in your list are stock bearings and oil seals which should be obtainable from a good bearing stockists, just take along your old bearings and seals for patterns.
For the Lister specific items you might like to try Marine Engine Services, located in Uxbridge, UK, their phone number is: (0)1895 236246.
