Lister Engine Forum
Welcome, Guest. Please login or register.
September 10, 2010, 02:54:34 AM
Login with username, password and session length
Search:     Advanced search
New Lister Engine Chatroom Added
http://listerengine.com/smf/chat/flashchat.php
Photo gallery - www.listerenginegallery.com.
61826 Posts in 5218 Topics by 2848 Members
Latest Member: StevenOOJames
* Home Help Search Login Register
+  Lister Engine Forum
|-+  Lister Engines
| |-+  Listeroid Engines
| | |-+  Piston/bore clearance?
« previous next »
Pages: [1] Print
Author Topic: Piston/bore clearance?  (Read 487 times)
cgwymp
Newbie
View Profile
« on: February 08, 2010, 12:08:52 PM »
Anyone know the spec for piston-to-cylinder clearance for an 8/1 (with aluminum piston)?
Logged
Listeroid 8/1
RobSmith
Newbie
View Profile Email
Re: Piston/bore clearance?
« Reply #1 on: February 08, 2010, 02:46:02 PM »
Hi,
I do not know what it should be but I had a similar dilema with my sons little Honda motorbike.
I cannot remember the exact values now but I decided that the piston clearance is measured when cold and the piston should always have the slightest clearance when as hot as it ever will be.
I think my guesstimate were about like this...
I think I chose about 120 Deg C as my hot temperature (2 stroke air cooled) for the cast iron cylinder.
I also thought the piston can maybe get to 170 deg C as the oil would be cooking on the underside of the piston pretty well at that temperature.
I worked out the thermal expansion of the cast iron bore with a 100 deg C temp rise and the cast ally piston with a 150 deg C temp rise.
I worked out the amount the clearance would reduce due to thermal expansion and then added a thou or half a thou.
I think it ended up at about 3 thou clearance.
We have not seized it up yet and it runs smoothly with no piston clattering.
I have no idea what it should be on an 8/1 but that was the logic I used on my sons little bike engine.
Rob
Logged
Pages: [1] Print
« previous next »
Jump to:
Sponsored by Outlaw Books
Powered by MySQL Powered by PHP Lister Engine Forum | Powered by SMF 1.0.9.
© 2001-2005, Lewis Media. All Rights Reserved.
Valid XHTML 1.0! Valid CSS!
