Lister Engine Forum
Welcome, Guest. Please login or register.
September 10, 2010, 02:02:39 AM
Login with username, password and session length
Search:     Advanced search
New Lister Engine Chatroom Added
http://listerengine.com/smf/chat/flashchat.php
Photo gallery - www.listerenginegallery.com.
61826 Posts in 5218 Topics by 2848 Members
Latest Member: StevenOOJames
* Home Help Search Login Register
+  Lister Engine Forum
|-+  How to / DIY
| |-+  Engines
| | |-+  Propane or Gas fuel for Lister/Petter etc using pilot ignition???
« previous next »
Pages: [1] Print
Author Topic: Propane or Gas fuel for Lister/Petter etc using pilot ignition???  (Read 563 times)
buickanddeere
Sr. Member
View Profile
« on: February 06, 2010, 07:11:53 PM »
  Anybody tried running a small diesel on primary propane or natural gas? I've heard tell of large scale diesel gensets or diesel irrigation pumps set up to vary the amount of "power" via regulating the amount of LP or nat gas  metered into the intake manifold.
   Instead of all the fuss and mess converting to spark plugs and an ignition system. The engine just starts and idles on diesel as per normal. The amount of diesel injected doesn't increase above base idle level. The LP or nat gas in the combustion chamber is ignited by the little "pist" of diesel being injected.
Logged
Stan
Kimberley, BC
Hero Member
Found in Kimberley BC
View Profile Email
Re: Propane or Gas fuel for Lister/Petter etc using pilot ignition???
« Reply #1 on: February 07, 2010, 10:09:48 AM »
There's been lots of discussion on here about this and the consensus has been that it is valuable as an additional source of fuel, up to a point.  The reason is that it cleans the cylinders and valves of carbon.  Just a tiny amount is needed though.  Another additive that cleans the engine is a small mist of water.  Occasionally done, this keeps the engine clean.
ymmv
Stan
Logged
Isn't it strange that people are happy to adopt epithets they would fight to the death to throw off had they been imposed?
Veggiefuel
Energy Machines Ltd.
Full Member
View Profile WWW Email
« Reply #2 on: April 04, 2010, 07:11:41 PM »
Have a look here.....
CarlB did a conversion to run a listeroid on natural gas. Seems to work well.
http://www.youtube.com/watch?v=AwPPui8Fyi0
veggiefuel
Logged
Pages: [1] Print
« previous next »
Jump to:
Sponsored by Outlaw Books
Powered by MySQL Powered by PHP Lister Engine Forum | Powered by SMF 1.0.9.
© 2001-2005, Lewis Media. All Rights Reserved.
Valid XHTML 1.0! Valid CSS!
