Lister Engine Forum
Welcome, Guest. Please login or register.
September 10, 2010, 02:58:08 AM
Login with username, password and session length
Search:     Advanced search
New Lister Engine Chatroom Added
http://listerengine.com/smf/chat/flashchat.php
Photo gallery - www.listerenginegallery.com.
61826 Posts in 5218 Topics by 2848 Members
Latest Member: StevenOOJames
* Home Help Search Login Register
+  Lister Engine Forum
|-+  How to / DIY
| |-+  Everything else
| | |-+  Three Phase to DC
« previous next »
Pages: [1] Print
Author Topic: Three Phase to DC  (Read 617 times)
Casey
Hero Member
From now on! If it ain't diesel - I aint goin!
View Profile
Three Phase to DC
« on: January 10, 2010, 03:30:21 PM »
I'm still on the hunt for a cheap method of getting ac onto the grid.  Here's a rectifier which seems close.  Those of you that actually know what the heck you're talking about might give me some advise.  Yes, I have enquired about other units on Ebay but this one looks pretty good.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130357875469&_trksid=p2761.l1259
I emailed the seller about the quality of the DC out and got this reply:
Depends on the load. This unit is rated at 60 amp max load - 50amp with connected-included fuse. This unit was/is used in Electrical Discharge cnc Machines. Although , EDM's require stable DC voltage to operate properely. This unit most of the time performs very well with most ac inputs.Depending on application, the AC input should go through a noise filter first. The diodes are replacable in this unit. Hope this helps
Am I to presume that the voltage out will be close to the voltage in and only uppy-downies are taken away?
Casey
Logged
Witte DB Generator
my Metro runs !
Hero Member
Mmmm BBQ
View Profile WWW
Re: Three Phase to DC
« Reply #1 on: January 10, 2010, 07:40:18 PM »
Casey
Depends on the load you present the rectifier with.  Light load, output DC close to the AC peaks.  Heavy load, closer to the AC 50% point.
Logged
ronmar
Hero Member
View Profile
« Reply #2 on: January 16, 2010, 07:17:59 PM »
Well the picture of the 3 phase rectifyer has no sign of any filtration, so it will have some ripple.
Single phase AC looks like this:
Single phase rectified DC looks like this(large ammount of ripple):
3 phase rectified DC looks like this:
Since 3 phase has two more phases(4 more positive going rectified peaks), it fills in the valleys seen on single phase rectified DC.
Single phase rectified can be made to look like this.  It takes a large filter capacitor to charge during the peak and carry the voltage output across the valley.  Note the sawtooth waveform as the cap discharges between the rectified peaks.  The larger the DC current draw, the larger the cap needed to maintain output voltage stability.
Logged
PS 6/1 - ST-5.
listerdiesel
Full Member
View Profile Email
« Reply #3 on: May 02, 2010, 06:06:11 AM »
We build large industrial battery chargers & power supplies, up to and over 100kW.
The thing to remember is conversion losses, the bigger and uglier thyristor supplies are only 65% efficient, so you have to factor that in when doing your calculations.
Low power factor is another issue with big transformers and phase control.
Peter
Logged
Pages: [1] Print
« previous next »
Jump to:
Sponsored by Outlaw Books
Powered by MySQL Powered by PHP Lister Engine Forum | Powered by SMF 1.0.9.
© 2001-2005, Lewis Media. All Rights Reserved.
Valid XHTML 1.0! Valid CSS!
