I've run mine out of fuel a hundred times and although I don't like to have to bleed the system I also don't mind to much anymore. Here is what I do. Fill with fuel of course, crack bleeder screw at filter until fuel flows out, close screw, crack banjo bolt at fuel pump until fuel flows out, tighten banjo bolt, remove injector line at pump, remove fuel pump check valve until fuel flows out (with cutoff lever down), install check valve and injector line. Crack line at injector. I place my middle finger on the back side of the injector tappet (under the pump) and turn the flywheel (with decompression on) until I feel the tappet reach the top of its travel then turn the flywheel either forwards or backward until I the tappet is at its lowest point and continue to rock the flywheel back and forth until fuel comes out of cracked line at the injector. Tighten injector line and continue to rock flywheel until injector creaks four or five times then start as usual. Keeping your finger on the pump tappet the whole time allows you to only have to turn the flywheel enough to move the tappet up and down, because it can get tiring. The engine may run like a hit n miss for a minute until the air is fully purged. Now you could just remove the check valve and wait for the fuel but it might take a while and it may leave a pocket of air somewhere that would make the engine stall completely. Hope this helps somebody.
