Author Topic: 1115 changfa injector removal  (Read 3667 times)
dakota3c06
« on: December 31, 2009, 08:24:40 PM »
Anyone have a procedure for taking out the injector on a Changfa 1115?  It looks like two bolts and a plate press the injector into the sleeve.  Is the injector itself threaded also?  Any idea on torque for the injector/two retaining bolts?  Also, is there an injector seal and is it reusable?  I have to replace the seals on my VW and 300d.
Thanks
Dakota3c06
dieseldave
Re: 1115 changfa injector removal
« Reply #1 on: January 23, 2010, 02:43:28 PM »
  On the Changfa , I believe it is 2 bolts and a plate. Loosen the bolts, then crank engine over to loosen the injector.
  VW is the same, at least the 02 I had was the same.
  300D is threaded and can be a BITCH unless you have the right tools.
  Usually the sealing washers are replaced upon installation.
