It has indeed been standing for at least 5 years, possibly more. It was installed in premises in Leicestershire, move to near Cambridge, where it stood outside, but sheeted over, and is now installed in a wooden shed by my house. Its previous owner (the one near Cambridge) saw it running before it was moved from Leicestershire, but it has not run since. I have freed off the injection pump, checked its timing (such as one can with such a vague timing mark on the block), and changed the oil etc. One distinctly odd thing was that it had no comression at all when I got it, because neither valve had any clearance and neither sealed as a result. I have adjusted the tappetts, with the result it now has some compression, but I am not convinced it has all it should have. I suspect muck on the valves/seats, but the rings may be stuck as well. I have turned it over with the injector out, but connected, and it injects into a tin, but I can't really judge the spray quality. I don't at the moment know if there is diesel vapour coming out of the exhaust, and in truth the pipe is probably long enough that it would largely have condensed by the outlet any way.
So far I have only tried to start it on the handle, without success. I must now get another battery so that I can motor it over. I am hoping that if I can get it started the first time it will clean valves/seats as it runs and possible loosen stuck rings if they are stuck. It is just that I need to start it that first time.
