Author Topic: Lister engines in storage  (Read 8663 times)
barry100
« on: September 09, 2009, 12:52:05 AM »
Hi All
 I have several Listers in Storage, the longest about 18 months and got to thinking the pumps and injectors may be gumming up, I inquired about storage/calabration fluid and the cost was about $250 for 20 Lts which is out of my price range for 3 or 4 engines, anybody use some other fluid or say a home made mixture
Barry
Oiler
Re: Lister engines in storage
« Reply #1 on: September 09, 2009, 11:43:27 AM »
Dont worry, they can store for ages, without problems.
My old Nuffield tractor is only started every three or four years and so far there has been no problems.
Torsten
1962 CS 6/1 for cutting firewood.
Armstrong Siddley AS1 for sale.
1937 Lister D
1918 Lister L
compig
« Reply #2 on: September 09, 2009, 12:27:50 PM »
Pumps & injectors will be ok as the diesel will be ok for quite long periods. Bores , rings & valves are the thing to be concerned about. Ideally the oil should be drained before storage and replaced with storage oil , engine turned over to circulate then thats it. Failing that squirt some engine oil down the  the intake and turn over to coat the bore and rings. Then spray some preservative oil down the intake and if poss down the exhaust port after removing the manifold. Many don't bother with anything and seem to get away with it but it depends on storage conditions. Condensation is the enemy , if the storage conditions cause condensation then bores will rust and valves will stick.
Lister A
Onan W3S Genny
Petter A1
Villiers C45 industrial
compig
« Reply #3 on: September 09, 2009, 12:29:31 PM »
Oh , forgot to mention , on single cylinder engines . leave the piston at TDC on the compression stroke , even if you haven't done any of the above !
Lister A
Onan W3S Genny
Petter A1
Startomatic
« Reply #4 on: September 09, 2009, 01:05:28 PM »
Hi Oiler,
wht Nuffield Tractor model is yours? my dad own a 342 at one time. alway remember the expose rotating brake drum ontop of the rear axle where i find standing room when getting a ride!
Lister 6/1 with ST5,Lister SL3, JP1
Yanmar Diesel L10,TS65,TS105 with Interpump hp head
Yanmar 3TN72, NT110 with ST5
Andoria S320
Kubota Z400 Twin Diesel with KEW 1500 hp head
Isuzu 25KVA Diesel silenced Genset
ChangChai EV80
JianDong 1115
Shineray250 watercooled- gasoline
ListerHRW3water
jzeeff
« Reply #5 on: September 09, 2009, 02:02:58 PM »
Some people plug up the intake and exhaust and put a desiccant inside.  Seems like it might help.
Oiler
« Reply #6 on: September 09, 2009, 08:12:47 PM »
Startomatic
It's an old 10/42 from 1966 and it was already here on the farm when i bought it.
1937 Lister D
1918 Lister L
WGB
« Reply #7 on: September 10, 2009, 01:32:04 AM »
Barry you really should sell them cheap fast before they're ruined!
I'll help you out!
There use to be a product that was in a spray can that would fill cavities with foam for long storage of pumps. Might look in that direction.
Startomatic
« Reply #8 on: September 10, 2009, 03:53:49 AM »
Hi Oiler,
is that 1042 come with a transfer box with 10 forward speed?
Andoria S320
ChangChai EV80
JianDong 1115
ListerHRW3water
    • Doug's Petteroid Stuff
« Reply #9 on: September 10, 2009, 11:13:21 PM »
I know a guy that has a storage container of Listeroids.....
I think theyt will keep lol....
Oiler
« Reply #10 on: September 11, 2009, 06:18:08 AM »
Hi Oiler,
Yup. Ten forward and two reverse.
1937 Lister D
1918 Lister L
matt
« Reply #11 on: September 16, 2009, 02:11:38 PM »
Hi Oiler,
Wow someone else has a Nuffield Tractor!!!!
I drove a Nuffield here in Australia as a teenager on my aunt's farm during my school holidays. Fantastic!!!!
This was really old. It was orange with "BMC Diesel" on the front grill.
Had a driving pulley on the side, also had the bucket accessory at the front. Pull the cord to tip 'er out!! ;)
Electric and crank start.
It only had 4 or 5 forward speed box. A very early diesel unit, just after the days of kerosene IIRC.
Great memories!!
Matt
« Last Edit: September 16, 2009, 02:14:17 PM by matt »
