Author Topic: HOW TO POST PICTURES TO THIS FORUM.  (Read 2847 times)
woodart
« on: September 05, 2009, 07:59:11 PM »
I had quite a lot of difficulty trying to post a picture to this forum. After searching I found two threads which solved the problem, but each by themselves where incomplete. So I have combined them here as follows:
Step 1…log on to lister engine Photo Gallery (top right corner of any forum screen) or go to:
http://listerenginegallery.com/main.php
Step 2…click on register and follow the instructions
Step 3…once logged in to Lister Engine Gallery, go to “your Album”
Step 4… Follow the steps to upload a file
NOTE you should have a pre-prepared .jpg file that you have shrunk down. If you don't, the picture size may be too big for Lister Engine Gallery.  You can use any photo editor to make the picture web compatible.
Step 5…left click on your uploaded picture so it is selected (larger) and in the center of your screen
Step 6… right click on it
Step 7…. left click on properties
Step 8.... A new window appears and you should copy all of the URL address.
Step 9….then go to the posting box where you want to post it  - left click on insert image - then spread  them apart       [/img] .......... [/img]   by putting the curser in between them and use the space bar to move  them apart - paste in between them the URL Lister Engine Gallery address and your done.
Step 10… click on the preview, check out if it worked.
YOU’RE DONE, CONGRATULATIONS!
« Last Edit: September 05, 2009, 08:00:51 PM by woodart »
clytle374
Re: HOW TO POST PICTURES TO THIS FORUM.
« Reply #1 on: September 06, 2009, 04:11:46 AM »
Quick, someone alert Doug.
