Hello again,
Amen to Jens' remark about not messing with the high pressure injection line. On multi-cylinder engines the designers go to great lengths to
use the same physical length of line to each cylinder so as not to have timing variations to each cylinder. Oils under injection pressures DO
compress by small amounts, and steel lines also expand during pressure pulses, (over 2000 psi in a Lister), so anything which varies the volume of the
delivery line will affect timing and injection characteristics. The oil preheat will be needed BEFORE the injection pump to allow it to flow quickly into
the pump barrel during the small fraction of a second that its intake port is open. Once you have hot, thin oil in the pump, and a warmed injector and
head, you only need to INSULATE the injector line to retain this heat. Get on line and read the wisdom of the many other veg burners. It's all been done
before, and it's not rocket science! Happy vegging, Regards, Combustor.
