Hi guys,
I've been running my CS for a couple of hours the other day and I noticed that my high pressure side of the fuel line to the injector is cool to the touch. I'm planning on running WVO in the future and know that I'll have to heat this up. (I'm not using the coiled copper tube at the left at the moment as I'm using diesel fuel currently, I tried it, but it got so hot, I'm scared the diesel might ignite or something else might happen!)
Recently I moved my fuel filter to the bottom position next to the pump as I fitted an engine mounted diesel tank.
The area on the head were the filter was removed from was very hot so that got me thinking:
Will a big copper block with small ID ports drilled into it as to make a zig-zag like tube through it, not significantly or partly heat the WVO fuel up to an exceptable level?
I will be heating it up with a loop around the exhaust pipe before the pump as well, I'm just trying to get away from using electrical means of heating it before the injector or to use minimal elec. heat to get it up to temp. just before the injector.
I'm just worried that the block might work in reverse, rather cooling the WVO to head temperature than heating it up more!
I have no idea what the temp of the WVO will be just after the pump, maybe someone has experience with this before I start making stuff?
At the moment I'm running on diesel fuel, would it not benefit fuel consumption from being heated before going int the injector?
A lot of questions guys, thanks in advance.
