Author Topic: The little CAT diesel  (Read 59824 times)
Horsepoor
  • West Palm Beach, Florida
Re: The little CAT diesel
« Reply #90 on: September 30, 2009, 11:07:30 AM »
I'd be interested in looking at the snowmobile pressure filler cap. Could you please post a link to the ebay store.
tymbo
Re: radiator
« Reply #91 on: September 30, 2009, 01:57:22 PM »
http://stores.shop.ebay.com/sledpartsofwis__W0QQ_armrsZ1
I ordered one of these radiators from surplus center.  Made for 13hp engine, it has 1" hose fittings, just like the CAT ;D
I found a pressure cap/filler neck on ebay from a snowmobile parts place, also with 1" fittings.
https://www.surpluscenter.com/item.asp?UID=2009091416031944&item=28-1685&catname=
bluetick
« Reply #92 on: March 05, 2010, 05:06:38 AM »
The 855 cummins without a turbo had a passage in the head from the intake to the oil gallery. It was about a 1/8th inch in dia. the rocker box continued the passage to just under the valve cover. Maybe these engines have a similar passage.
When swapping out the heads if you forgot to plug this passage on a turbo engine, you could loose a LOT of oil as the boost pressure filled the crankcase.
