I have a 8/1 on a start-o-matic set, and it appears not to have the stop lever. Is this normal on start-o-matic engines? Also, what does the stop lever actually do to stop the engine; does it force the pump control rack to the no fuel delivery position, or does it stop the pump plunger moving, or what?
Also, how does one prime the fuel system on a start-o-matic set, because as I see it when the decompressor is operated the pump delivers no fuel, and conversely to get the pump on maximum delivery the thing is compressing. On my Petter one can fill the injector pipe by operating the priming lever, or by winding it over decompressed. On the Lister I assume I have to take part of the stop mechanism apart, so that I can wind it over decompressed but with the pump on full delivery. Is this the way to do it?
Ian
