Dad bought one of the harbor freight 3600 rpm heads, and is relatively pleased with it. but it is only used for intermittent service.
i would be concerned about the brgs used, and if i was to use one for main power source would probably replace them with the best i could find.
also i would limit the draw to 5kwatt continuous, and figure some way to shock mount it to keep away vibration if possible,
although i am not crazy myself with 3600 rpm, i guess if it has been balanced well maybe it would last.
another concern would be the driving mechanism, using a microgroove belt on a lister would get you up to speed, one also has to remember
to check the engineering charts on the amount of power a given groove count can stand using the quite small driven pulley diameter, you might have to step up to more grooves to pull the power "effectively" and perhaps more importantly "dependably".
just because a given belt is stated to be able to take a given hp, does not mean it will do so dependably in all applications, some apps such as such a large step up in speed greatly reduce the hp rating of a given belt.
such things as c/c distance, degree of contact, surge loads (such as a welder), and the fact that it will be driven by a single cylinder, can in some cases remove up to 50% (or more) percent of a given belt rating.
just some random thoughts and observations
