Author Topic: Pics of my Kissan 4hp petteroid  (Read 12990 times)
panaceabeachbum
    • Thompson Machine
« on: July 26, 2009, 06:44:58 PM »
Here are a few pics of the petteroid 4hp i bought from another member here via ebay.  Seems to run like a top.
« Last Edit: July 26, 2009, 06:51:05 PM by panaceabeachbum »
panaceabeachbum
    • Thompson Machine
Re: Pics of my Kissan 4hp petteroid
« Reply #1 on: July 26, 2009, 06:45:48 PM »
panaceabeachbum
    • Thompson Machine
« Reply #2 on: July 26, 2009, 06:47:30 PM »
panaceabeachbum
    • Thompson Machine
« Reply #3 on: July 26, 2009, 06:54:54 PM »
« Last Edit: July 26, 2009, 06:57:07 PM by panaceabeachbum »
oliver90owner
« Reply #4 on: July 26, 2009, 07:42:56 PM »
quick vid clip
Put it on a lead and take it for a walk?
Regards, RAB
panaceabeachbum
    • Thompson Machine
« Reply #5 on: July 26, 2009, 07:45:27 PM »
It does slide around a bit, not like hatz though , it jumps up and down about 3 inches
sid
« Reply #6 on: July 26, 2009, 09:59:01 PM »
A very brave individual/ email me some time and I can help you a little on what to watch out for and how to control it a little more/sid
8 hp stover 1923
8 hp lg lister
1932 c.s bell hammer mill
4 hp witte 1917
5 hp des jardin 1926
3 hp mini petters
2hp hercules 1924
1 1/2 briggs.etc
oliver90owner
« Reply #7 on: July 26, 2009, 10:29:02 PM »
Do you have one?  Which?
I have a couple:  E75 on a 4 1/2kVA gen - black smokes at a bit over 3kW - and a bigger one, about 8 horse.  It tries to escape but it only stands on it's own footprint and was used to vibrating for all of it's previous life as it came off a Bomag compactor.  It was seized when I bought it but I easily freed it off by removing the cold start holder and oiling it.  Good compression so I just started it and ran it to be sure it would stay free. It might find a use one day, or replace the E75.......
Regards, RAB
sid
« Reply #8 on: July 26, 2009, 11:03:48 PM »
I still have 2 left/ both are lg gear and are pretty good engines/ I got rid of the petter from hell/ I finally tamed it a little. it now runs  but I would never trust it// also i would never start any petter with the air cleaner on it..and a good wrench in the back pocket to loosen the injector line/the petter could be a good engine but it has earned a well deserved reputation for runing away and falling apart,leaking etc.the petter has a higher run rpm/ I think the lister is easier to start.sid
8 hp stover 1923
8 hp lg lister
4 hp witte 1917
3 hp mini petters
2hp hercules 1924
1 1/2 briggs.etc
panaceabeachbum
    • Thompson Machine
« Reply #9 on: July 26, 2009, 11:21:48 PM »
please get me up to speed Sid, I have read every single post in the petter section and was under the impression that the run away issue were the Ash petters sold thru utterpower and not the kissans solt thru altpro , but other than reading here and some indian airplane engines I have no experience with indian diesels.
The air cleaner was not bolted in place, just sitting loosley on there for the pics , very easy to lift straight off if the need to smother arises .   I am very interested to hear any comments or advice on how to improve this engine , although the indian build procedures are a little third world I would think this engine would/could have the potential to be a very good engine.
It does look to be slideing around a bit in the video but I have a number of US made petrol burners as well as a couple of high qaulity german diesels that make that video look like the petter isnt even running. Compared to my 10 hp aircooled petter single the little indian engine is very tame .  The brit built air cooled is turning a 6kw 3phase gen and jumps up and down like a whacker packer
sid
« Reply #10 on: July 26, 2009, 11:58:13 PM »
I sent you a email with a picture of the speed control that i use and it seems to work very well/sid
8 hp stover 1923
8 hp lg lister
4 hp witte 1917
3 hp mini petters
2hp hercules 1924
1 1/2 briggs.etc
panaceabeachbum
    • Thompson Machine
« Reply #11 on: July 28, 2009, 11:53:54 PM »
Hi Sid , I didnt seem to get it for some reason , could you send the pic again? Thanks Richard
sid
« Reply #12 on: July 29, 2009, 12:00:51 AM »
I resent so more pictures to your email address on your profile/ if you do not get them .send me a email and I will resend them/sid
8 hp stover 1923
8 hp lg lister
4 hp witte 1917
3 hp mini petters
2hp hercules 1924
1 1/2 briggs.etc
sid
« Reply #13 on: July 29, 2009, 12:59:14 AM »
Richard/ if you are in the pan handle of Florida/ do you ever make the Flywheelers show in Avon park/I usually make the swap meet in jan. and the show in Feb.sid
8 hp stover 1923
8 hp lg lister
4 hp witte 1917
3 hp mini petters
2hp hercules 1924
1 1/2 briggs.etc
panaceabeachbum
    • Thompson Machine
« Reply #14 on: July 29, 2009, 01:42:30 AM »
I might attend the swap meet this year, we are def headed to the show at Zolfo springs in March
http://www.old-engine.com/zolfo.htm
