also don't forget any grit that makes it through the injection system ends up in the cylinder
where it accellerates ring/cylinder wear, and some ends up in the crankcase, where it wears every other
moving part.
back in the 50's cummins ran destructive tests on an engine in the lab
they determine exactly how much dust it took to ruin the engine,, interestingly
it didn't matter how the dust got into the engine, whether through the air intake, added into the
oil or added into the fuel. the result was always the same
so you might wanna factor in a complete engine overhaul on a regular basis, regularity will be established
through empirical means.
fwiw, because the lister/oid has no full flow lubrication filtration the problem will probably be worse than in
an engine that has such filtration.
i think i would want to process that oil as much as i could within economic reason before i did my testing
milling, heating, centrifuge, more heat, followed by a couple stages of filtration oughta get you close?
how does bunker oil compare in price per gallon to pump diesel?
interesting project though, look forward to how it works out for you
