Well... I've made some decent progress at last
The slip-rings came off easily enough, in the end, so next off was the bearing (seen just behind the rings in the pics above, with the tube sticking upwards. This whole area was a big solid mass of grease. Once removed, the back of the alternator slipped off with minimal use of a lump hammer (and a cloth, to protect the paint). A rubber mallet would have been a better tool, but I couldn't find it...
(Apologies for the piss-poor photos, only got my emergency backup camera down here @ the shed just now - have now updated some of them to clear versions...)
Pulling the back off revealed the bushes & internal slip ring, the bushes were then removed:
Removing 4 bolts at the front, and with a little gentle hammering, the entire core, pulley & front casting could be withdrawn easily:
It's pretty full of crud...
So... the next jobs are:
1) A major clean-up of all the electrical bits. I'm not sure what to clean them with, though - a plain pressure washer? Or should I soak the whole shebang with Gunk first? The dirt appears to be a mixture of soil and grease...
2) Removing that damn pulley:
Current idea is to grind the lip off the end of the shaft, so the pulley can at least come over the end; then make a puller which bolts into the three large bolt holes you can see in the pic above and pushes against the shaft to try to pull the pulley over the end of the shaft. I can use oxyacetelene to heat the pulley to assist the over-the-front removal.
3) Removing the rest of the ironwork from the shaft. In order to do that, I'll need to remove the bearing at the end of the shaft:
Any ideas how I go about that? Heat? Or should it push off with a bit of WD40 & effort?
4) Test all the electrical bits to make sure nothing's broken or shorted out. Time to get the wiring diagrams out...
