Author Topic: What size mig welder is compatable w/ 6/1 ST5?  (Read 4132 times)
wldhoss
« on: April 15, 2006, 04:25:51 PM »
In a year I will be off grid. Power lines will be 34 miles away. I am looking to buy a new Mig Welder and need to figure what is the biggest amperage welder I can push with a 6/1-ST5 or 10/1-ST5. Thanks JP
GuyFawkes
    • stuff
Re: What size mig welder is compatable w/ 6/1 ST5?
« Reply #1 on: April 15, 2006, 05:54:01 PM »
140 amp welder (toy like mine with a 50% duty cycle) pulls about 3 Kw.
« Reply #2 on: April 15, 2006, 07:10:26 PM »
go with the 10/1 and a 220 volt 160amp like one of the hobarts or millers
and step up to gas shield, i don't think you will  be happy with flux cored
co2 welds a bit hotter than straight argon, and mixed gasses also can help pick up the heat
(up to 25% helium in an argon gas base really picks up the heat, but can be tricky to master)
GuyFawkes
    • stuff
« Reply #3 on: April 15, 2006, 08:22:34 PM »
worth  checking out my man's site if you're new to mig
http://www.mig-welding.co.uk/
« Reply #4 on: April 15, 2006, 11:22:24 PM »
I've run my cheapo Century MIG with my 6/1 and it ran great. Well just as good as utility power any way. I'm using .030 flux core wire on the high (don't know what that amperage is). I used the same MIG welder to build my base too. On high I think it only has about a 10% duty cycle though so it takes patience.
wldhoss
« Reply #5 on: April 16, 2006, 04:47:07 AM »
Thanks for the info. Miller has a 180 that will probably will work. I have a costco century 130 that I need to replace.  JP
