Author Topic: banford z10 ground pounder  (Read 3838 times)
aloris
« on: May 27, 2009, 02:16:43 AM »
went to see a buddys direct inj banford 800rpm to see the practicality of running my 8 pole gen with it. runs w/almost no vibes or mechanical noise but, it sends the combustion knock into the ground that can be felt standing on a tree root 50 ft away. we put about 3000 watts of load on it . it was solid mounted to slab footing. this engine would be a candidate for some sort of flexable isolator. any ideas? rubber,wire rope,or viscous?  mike a
http://listerenginegallery.com/main.php?g2_view=core.DownloadItem&g2_itemId=2016&g2_serialNumber=2
http://listerenginegallery.com/main.php?g2_view=core.DownloadItem&g2_itemId=2013&g2_serialNumber=2
http://listerenginegallery.com/main.php?g2_view=core.DownloadItem&g2_itemId=2019&g2_serialNumber=2
compig
Re: banford z10 ground pounder
« Reply #1 on: May 27, 2009, 09:43:02 AM »
Do you mean Bamford by any chance ?
Lister A
Onan W3S Genny
Petter A1
Villiers C45 industrial
apogee_man
« Reply #2 on: June 06, 2009, 06:11:22 PM »
Can't see the pics...  security violation of some sort.
My guess is, you posted links that are from when you were logged in...
Need generic links instead....
Thanks,
Steve
rcavictim
« Reply #3 on: June 12, 2009, 01:39:53 PM »
Me too.  Can't see the pics...  security violation of some sort.
-Changfa 1115
-Want Lister 6/1
