Steve:
just to get this clean in my muddled mind
if my stc 3phase head is 230/400
that makes it 400volts across any pair of phases xy, yz, or zx
and therefore 230 volts across any phase to neutral
so i would want to regulate the 400 volts down to 208 in order to get 120 from neutral to each leg, but
in doing so wouldn't i be cutting the kva capacity of the head roughly in half?
seems like one would do far better keeping the oem excitation system and using a 3phase transformer
or set of single phase setup for 3 phase
that way you get full capacity (kva) or nearly so, and
by virtue of resolution better voltage regulation anyway?
another question if i might,
can you explain to me how an electronic avr is going to reduce flicker?
its hard for me to get my head around how any avr is going to actively compensate for flicker when it
is always behind the event?
i suppose some sort of microcontroller and some very good coding, so that samples could be made, averaged
and compensation made on the fly,, but
such a controller certainly is not going to be easy or cheap in my opinion.
even at best there would have to be some flicker to sample so the puter could make the computations, and set
the control... which might work ok at a fixed steady load that never fluctuates very often. something most folks
don't have (a fixed load)?
more questions than i can find answers for
