Author Topic: polystyrene added to bio-diesel (foam cups)  (Read 13967 times)
« on: May 01, 2009, 07:18:26 PM »
Article at newscientist.com
http://www.newscientist.com/article/dn17066-plastic-cups-could-boost-auto-performance.html
"One can recycle any kind of plastic, but if you are camped in a remote area, recycling is not an option," Kong says. "Turning plastic into fuel is a way to get rid of garbage and generate electricity."
Kong and colleagues dissolved polystyrene – a polymer used to make disposable foam plates and cups – into biodiesel at concentrations ranging from 2 to 20% polystyrene by weight. "A polystyrene cup will dissolve almost instantly in biodiesel, like a snowflake in water," Kong says, although the plastic doesn't break down as well in petroleum-based diesel and other liquid fuels.
After 5% though, it tends to increase the fuel visciocity and gum things up.
WGB
Re: polystyrene added to bio-diesel (foam cups)
« Reply #1 on: May 01, 2009, 09:40:06 PM »
Thanks now I have to staring eating at fast food places again! ;D
Veggiefuel
  • Energy Machines Ltd.
« Reply #2 on: May 05, 2009, 03:26:30 PM »
Biodiesel is virtually a carbon neutral fuel. I wonder what they are trying to achieve by adding dissolved plastic (hydrocarbons) ?
I don't think it would boost cetane, add power, or burn cleaner.
First impression is that it allows them to use the trusty old diesel engine as a garbage can to burn the refuse in minuet quantities.
It would be interesting to see the effect on the exhaust emissions.
Veggie
« Reply #3 on: May 05, 2009, 11:41:10 PM »
Veggie
Right, rather than trucking waste out, to be pounded into a landfill, burn what burns easily.
lowspeedlife
  • old iron for a new age
  • no i'm not no cowboy
« Reply #4 on: May 06, 2009, 01:09:46 AM »
Sounds like a "do only if told to & if uncle sam is footing the bill " sort of thing to me. I don't think I would want to "plastic coat" the insides of my pumps, injectors & lines. if the stuff disolves so easily, dissolve it, reclaim it & make more cups & plates out of it!
Scott R.
omega 20/2 listeroid
HitorMiss
« Reply #5 on: April 30, 2010, 12:59:23 AM »
I say dissolve as much as you can in your biodiesel, then slice off pieces to throw in your oil-burning stove.   ;)
I have no idea what to do next...
