Bob, yes the crank rod journal is rifle drilled to oil the big end bearing. The rod is also drilled with the two splash holes in the top side and it has the grooved upper shell installed. I would be a little worried that the centrifugal slinger would not provide enough voulme to the bearing, even if it did, if the oil pump quit pumping the catch ring would run dry and that would surely spell disaster. So what do you think, leave it as is or go to a hollow dipper?
I have some points to make on this....
1, I recommend close inspection of the oil output tube that feeds the oil pickup ring. If you manually pump the oil with the lever, the oil only dribbles down the side of the tube. There does not seem to be enough pressure to shoot it out and make the jump across to the oil ring.
Having said that, the pump would probably pump harder when the engine is running and may make the jump. I am thinking of restricting the flow tube that feeds the roller bearing on the other side to help feed the oil ring better. Both roller bearings do not really need this special oil feed tube to them as there is a plenty enough oil splashing around in there to oil them. They are very exposed to the splashing. The single sump Listeroids just leave these roller bearings to splash lube anyway.
2, If the pump was to fail, the extra holes in the top of the big end bearing would only be of benefit for a short time. This is because the top sump would eventually empty down into the lower sump from the slinging action of the oil dipper...which would eventually have nothing left to sling!! Maybe we could avoid this by filling up the oil level right up full until the dipper level similar to the models with the single sump. Maybe then the engine would survive without an oil pump. Then hopefully the amount of oil flying around in there may be enough to be caught in the oil ring without the pump working. I live in hope that it will.
regards,
Matt
