Author Topic: 15km 3 phase st head wiring question  (Read 3321 times)
tlfrantz1
  • Leapin' Listeroids
« on: April 17, 2009, 12:04:55 AM »
Guys,
Got a 15kw 3 phase ST head here, and I have some wiring questions...on the "138-240 volt" diagram it looks like I have to put jumper bars between the terminals---is this true because the gen didn't come with the bars. It was originally wired for 480v and it didn't have jumper bars.
Thanks!
Tommy
Sorry, all the photos are in listerenginegallery under tlfrantz1
http://listerenginegallery.com/main.php?g2_itemId=1435                      Label
http://listerenginegallery.com/main.php?g2_itemId=1438                      New doghouse
http://listerenginegallery.com/main.php?g2_itemId=1441                      My gen
Q: What is the difference between God and Barack Obama?
A: God doesn't think He's Barack Obama.
lowspeedlife
  • old iron for a new age
  • no i'm not no cowboy
Re: 15km 3 phase st head wiring question
« Reply #1 on: April 23, 2009, 10:21:04 PM »
Yea, you are correct, you need three jumper bars in there to make the switchover, you can use some apropreatly sized wire & ring terminals. i would use XHHW or THHN insulation if you can find it. not sure what they would call such things on that side of the pond.
    Scott R.
Scott R.
omega 20/2 listeroid
rcavictim
« Reply #2 on: April 24, 2009, 05:36:54 AM »
From the title I figured this was gonna be a much longer question.   :D
-Changfa 1115
-Want Lister 6/1
