Author Topic: Lister Found  (Read 3341 times)
arborlis
Lister Found
« on: April 14, 2009, 03:47:54 PM »
Greetings, a friend was given a large air cooled original Lister engine yesterday. It says 26hp 2200rpm, serial #138 HB 219. It has a twin disc pto and compression releases on both cylinders. It was run last year but has been sitting since. Any info/parts available? Is this engine worth restoring?
Thanks!
Anthony
Lister Rob
Re: Lister Found
« Reply #1 on: April 14, 2009, 04:24:05 PM »
 If you had a picture up it would be very helpful in answering your questions but almost all listers are worth keeping, just because it is a true lister.
listerdiesel
Re: Lister Found
« Reply #2 on: April 14, 2009, 05:46:22 PM »
Sounds like an HB2, be worth checking those number/letters again, just in case it is an HR2.
138 is the serial
HB is the Type
2 is the number of cylinders
19 is the year of manufacture, 1969
Peter
arborlis
Re: Lister Found
« Reply #3 on: April 15, 2009, 05:13:01 AM »
The numbers are correct, it's an HB2. Is the HR a better engine? Are overhaul kits available? Can this engine be started by hand? Can the injection pump be rebuilt?
I live in Memphis Tennessee and I'm not aware of any parts houses here that carry English diesel parts.
Thanks
