Hello All,
After a few hours of running my HA 2 is now having a few issues.
First off, it is only running on one cylinder. By means of swapping the injectors, I have determined that the injectors are fine.
The injector pump of the non running cylinder seems to be fine as fuel shoots out when no injector and pipe is hooked up, having said this, I do not know if the pressure is ok.
Also, I have bled at the injector, so I presume it can't be caused by an air lock.
The other issue that I can't seem to control is an air leak under the injector. I have cleaned the seating and put a new (copper) ring in but after a few minutes of running the smoke re-appears again and it is loosing compression. Looking at the ring and injector, the leak is each time on the same spot and it is between the ring and injector. Could this be due to inproper injector installation.
Thanks for any help
Henk
