I suggest that you check the operation of the fuel pump, including that the rack moves properly, and check and lubricate the external governor and stop/start linkage. I have a SOM set which hasn't run for a good five years, and probably rather more, and the injection pump was stuck tight with fuel deposits (see earlier post about freeing it). The other problem I envisage, but time will tell whether or not it really will be a problem, is mucky contacts etc on the relays in the two control boxes.
Ian
