Good day,
I am trying to figure out how to stop the compression leak I am getting with my Comp, change over valve. I tried cleaning the plunger end to get it to seal better, but I still get leaks, no matter how tight I crank the handle.
Is the plunger just worn out, Am I missing some copper seals, if sio, where do they go??
When it cranks over, you can hear the air hissing in and out of the small holes in the large threaded part..
I tried putting a solid washer to plug the small hole, then cranked the handle, and she will fire right up, If I try to start it cold with the valve on low comp, I just cant spin it fast enough to start.. So I would really like to get it fixed..
Thanks very much...
