I have freed off the injection pump from my Lister, but in doing so I have lost the relationship between the rack and the pinion.
I discovered that the pumping plunger was stuck in its sleeve, with the rack and the pinion both free to move within the small amount of slack. I soaked the pump in diesel fuel for many hours and was eventually was able to tap the plunger out from the top using a bronze drift through the delivery valve seat. Therefore I removed the plunger completely. At this point the pinion seemed to be held in by the spring seat, but suddenly I was aware that the spring seat and the pinion had fallen out. However the problem is that there is no alignment mark on the rack, or at least I can't find one. The only markings on the rack are the word stop and an arrow on one end, which is the end that sticks out most when the engine is not running.
I then cleaned everything, there being alot of sticky deposits around the rack and the pinion and in the pump chamber itself, that is the top of the bore of the main pump sleeve. However they are now clean and the plunger slides in the sleeve a treat.
Now the real question. What is the alignment of things. I deduce that the axial slot in the pump plunger should align with either then inlet hole or the one opposite it in the sleeve when the rack is in the stop position. Is this correct, and if so does it matter which of the two holes mentioned? With the mark on the pinion towards the rack, and the other mark on the pinion aligned with the mark on the plunger the slot is towards the hole in the main sleeve that is by the screw that holds the main sleeve in the body. This is plausible, but is it correct?
Your comments and guidance please.
Thanks,
Ian
