Author Topic: frame rigitity+jaw couplings  (Read 8340 times)
aloris
« on: February 22, 2009, 10:58:35 PM »
hello all, just finished coupling hr2 w/st10 gen. frame is 5x5 h beams spaced 24 inches on centre. eng+gen sit on 3x3x1/2 welded to beam webs. all is fine on cast iron lay-out table . pick up unit and set it down on imperfect surface and coupler sounds like a dog working a rubber chew toy. shaft centres 14 inchs above frame centres. ok for stationary bolt down . a failure for portible use. any ideas? aloris
Re: frame rigitity+jaw couplings
« Reply #1 on: February 23, 2009, 03:09:01 AM »
H and I beams are rigid in bending but about worthless on their own in twist
if you can, you might consider welding in round section crossmembers between the two beams
this will dramatically stiffen the beams from twisting.
you wanna make sure everything is plumb and level before you weld them in, because afterwards the beams will not
twist any appreciable amount (which is what you are after anyway)
torque tube, torque box construction is very rigid and will keep thing from twisting under load
it is this twisting too and froe that makes the drive coupler play hell with its spider element
if you go the route of round crossmembers, remember to make them as large in diameter as you can
after installation the tubes will maintain the beams from twisting, because to do so would require the round crossmembers
would also have to twist, which they will not to any appreciable degree if they are reasonably large in diameter.
compig
« Reply #2 on: February 23, 2009, 09:48:45 AM »
Box section would have been better to make the frame from.
Lister A
Onan W3S Genny
Petter A1
Villiers C45 industrial
« Reply #3 on: February 24, 2009, 02:31:57 AM »
can you put the pipes in as crossmembers between the I beams at the front and rear?
if so you will accomplish the same thing, and it might look better? fit nicer? easier to fit and weld?
wrightkiller
« Reply #4 on: March 23, 2009, 10:59:46 PM »
wrightkiller
« Reply #5 on: March 23, 2009, 11:19:58 PM »
Left click on the picture  to enlarge it     then copy the address     then paste it in    O.K.
« Last Edit: March 23, 2009, 11:23:24 PM by wrightkiller »
xyzer
« Reply #6 on: March 24, 2009, 01:48:59 AM »
No 2 floors are the same for a portable. Mine always sets good with 3 legs. No rock on uneven ground and it doesn't twist the frame. Worth a try?!
Vidhata 6/1 portable
Power Solutions portable 6/1
Z482 KUBOTA
lowspeedlife
  • old iron for a new age
  • no i'm not no cowboy
« Reply #7 on: March 24, 2009, 01:52:29 AM »
Looks really good aloris, I especally like the crank handle holder & the spring mounted breaker panel!! Thanks for the pics,
   Scott R.
Scott R.
omega 20/2 listeroid
WGB
« Reply #8 on: March 29, 2009, 02:34:01 PM »
Sweet!
hotater
« Reply #9 on: May 08, 2009, 07:30:59 PM »
Aloris--  (Are you a tool holder?)
I'm with Mobile Bob as to the solution of the twisting problem.  You have plenty or room to install four, four inch steel pipes between the I-Beam webs.  Cut through one web, run the pipe through, butt weld the blind side and fillet weld the pierced side.
The alternative is to X web the outsides of the I-Beam like bridges and trestles are done to make the members resist twisting.  The pipe seems the much easier choice.
Very nice job!!
prof.blink
« Reply #10 on: June 12, 2009, 05:25:04 PM »
good morning all, am i missing something? did you ever walk up to a crowd of people looking up at the sky and there was nothing there? what gives? blink
AdeV73
« Reply #11 on: June 12, 2009, 06:12:15 PM »
Aloris is no longer a member (hence: guest under his name). I presume that wherever the photo used to be hosted, it isn't any more. Hence, the blankness...
Just one of the side-effects of a hyperlinked world...
