Hi everyone,
The guys in the fab shop where I work have finally agreed to build the base for my Changfa generator assembly.
I have been bouncing back and forth between belt driving or direct driving the ST-5 head.
I have about 2 days to finalize my decision.
There are pros and cons to both.
BELTS:
- The Changfa comes with a 3 groove drive pulley installed on the flywheel
- Belts are easy to align and install
- I can run the engine at 1500 RPM and drive the head at 1800 rpm.(Perhaps quieter and longer engine life)
COUPLING:
- needs a custom coupling adaptor ($400 approx.)
- simple layout (other than alignment shims)
- Compact
- Quiet
The Changfa has an electric starter, so hand cranking is usually not a concern.
Input from owners of direct drivers and belt systems would be most appreciated.
Veggie
