Don't forget to check out the LEF Gallery! Exclusively for LEF members, an ideal alternative to Photobucket, Flickr, etc. It's FREE, and best of all totally AD FREE! Just click the link!
Should I be worried about this?Yes. Movement at the small end will be magnifying the clearance to the small end but 'a few mm' means little to me. Need a definitive check on that clearance.Regards, RAB --------------------------------------------------------------------------------Matt....I agree with Richard, it is NOT GOOD for a big end bearing to have any noticeable movement. Goto your local autoparts store (FLAPS, friendly auto parts store) and buy some plastigauge, it's cheap, easy to use and gives fairly accurate readings where nothing else can work.Stan --------------------------------------------------------------------------------MattHow thick are your shims? If they are Indian shims then they could be way to thick.Shims can be made out of any old beer or coke can.Take the shims out and torque up.If its tight then add one shim and try again.Keep adding shims evenly to both sides untill the rod moves without binding.
