Let me know what you are doing in the way of restoration with yours, maybe we can compare notes.
Stan
Hello Stan,
I started of with just a block, crank & flywheels! Luckily a friend of mine worked at a place which use to repair these and I manage to get brand new piston, ring, bearings exec. from him.
All the most important inner parts and I've been told that it's just about brand new now!
I hunted allover for an idler gear, even tried to get one from India, but eventually I found a shop in a small town over here with a lot of spares.
The cylinder head are kind of stuffed, corrosion got the better of it and there was a hole from the water jacket to the injector tube, but we managed to fit an aluminum sleeve into it.
Someone ignorant also tried to drill out the compression ratio valve and I cannot get it out without risking further damage. I'll be looking for another head, but in the meantime this one will work.
The engine runs perfectly and I'm now in the process of connecting a generator to it. I found an old one from a Ruston & Hornsby setup.
Its a 220VAC & 24VDC alternator of 3kW at 50Hz. I'm having trouble getting it to work, but some guys on another forum are helping me out.
It says on the name plate it was made by Anderson Generator Mnf in Johannesburg, South Africa, but I think they were the original inventors of re-branding in ZAÂ
My goal in the end is to automate it when the power goes out and also to run it on WVO. I use to work in an electro-mechanical environment and I'm sure I'm up to the taskÂ
I'll happily exchange notes with you if I can help, have a nice day.
