Author Topic: TRB Crank HELP  (Read 25270 times)
tigger
TRB Crank HELP
« on: December 15, 2008, 10:30:15 PM »
hi there
how do I adjust the play of my TRB crank??? :-\
« Last Edit: December 15, 2008, 10:34:41 PM by tigger »
compig
Re: TRB Crank HELP
« Reply #1 on: December 15, 2008, 10:57:26 PM »
Gotta be by shims behind the bearing housings I would think ?
Lister A
Onan W3S Genny
Petter A1
Villiers C45 industrial
1958steveflying
Re: TRB Crank HELP
« Reply #2 on: December 15, 2008, 10:59:12 PM »
Or extra gaskets like the end float on a standard crank.
lendusaquid
Re: TRB Crank HELP
« Reply #3 on: December 15, 2008, 11:48:48 PM »
Have you got to much or to little end play?
tigger
Re: TRB Crank HELP
« Reply #4 on: December 16, 2008, 06:44:34 PM »
I have a gap of about 4mm between the left housing and the case
1958steveflying
Re: TRB Crank HELP
« Reply #5 on: December 16, 2008, 06:58:13 PM »
If the bearings are fully onto the crank and the and the outer carriers are fully into the outer housings then it will need that gap taking up with something... But 4mm sounds way to much.
  phone Steve at SEP and ask the question.
tigger
Re: TRB Crank HELP
« Reply #6 on: December 16, 2008, 09:09:22 PM »
Steve at SEP ??????????
12 gauge
Re: TRB Crank HELP
« Reply #7 on: December 16, 2008, 09:25:34 PM »
I made a bunch of gaskets (joints) of various thickness material for the main bearing housings, and by trial and error added or removed them untill I had just got rid of end play in the crank.  Some are made of plain typing paper.  I have read of others using a few thousandths of end play in the crank for TRBs but I think they should be just snug like the wheel bearing on a car.  Engines with bush bearings would need some clearance though.  Try to have about the same thickness of gaskets under each bearing housing.
Re: TRB Crank HELP
« Reply #8 on: December 16, 2008, 09:42:57 PM »
I would think with that much space that it might be a good idea to start with a couple of 1.5 mm steel shims.
1958steveflying
Re: TRB Crank HELP
« Reply #9 on: December 17, 2008, 08:57:18 AM »
 Hi Ralph when i previously mentioned Stationary Engine Parts this was your reply.
 http://listerengine.com/smf/index.php?topic=4076.msg49134#msg49134
So i made the assumption thats who you purchased the crank etc from.
  Steve
tigger
Re: TRB Crank HELP
« Reply #10 on: December 18, 2008, 10:20:06 PM »
hi Steve
yes that's right I got the bits from there.
it's just that I have a genuine Lister 5-1 & I'm trying to fit a trb crank, but the housing seems to be not wide enough
lendusaquid
Re: TRB Crank HELP
« Reply #11 on: December 18, 2008, 11:49:17 PM »
Well i would suggest that it is not fit for purpose and ask for a replacement bush crankshaft and bush bearings.I presume that you have got the TRB bearings in the housings correct ?.
nobby
Re: TRB Crank HELP
« Reply #12 on: December 19, 2008, 12:44:24 AM »
Do you have any input from SEP the supplier, do they supply shim kits?  I would of expected shim kits would be part of the supply.  A gap is not the end of the world this would not be a direct bolt up anyway some form of shim clearance adjustment will be required.  4mm is quite a gap though.  So if no help from SEP then get some shim stock and make your own.  I would not recommend gasket paper as this is not really definitive I.e it will change clearance as you tighten.  As to how much well I can tell you that other engines that I have worked on with TRB's call for 0.002" - 0.004" (does SEP have a recommendation? pays to at least ask them).  So start of with say 2 thou and then run and check temp if they start getting warm then adjust.
cheers
Nobby
2 x Lister CE's
Looking for a CD
Stan
Re: TRB Crank HELP
« Reply #13 on: December 19, 2008, 01:37:03 AM »
May I ask why you are trying to convert a genuine Lister to trb's?
Stan
nobby
Re: TRB Crank HELP
« Reply #14 on: December 19, 2008, 02:54:19 PM »
Stan
Judging by previous posts it appears to be a cost based decision.
cheers
Nobby
2 x Lister CE's
Looking for a CD
