Never had this started but I'm sure it has sufficient compression to run as it takes off and runs along if any sort of oil is spritzed into the intake. I'm pretty confident that the fuel system is primed as I've pressurized the tank side with a primer pump and then bled all the bleeding points, multiple times. The motor is acting like the fuel shut off has been pulled but I don't see one to unpull. I'm curious as to how the injection pump should feel. There is a shaft running across the bottom of it that is about 3/8th inch in diameter. If you are looking at the bleed screw the shaft seems to be pushed to the right. The right side of the shaft isn't connected to anything but it has a pin through it that appears to prevent the shaft from pulling out through the pump if pulled to the left. The left side of the shaft is attached to the governor mechanism. The shaft rotates a little but seems locked from moving from the left or right but I dont know if it is the governor that's locked or the shaft. So,
1. Should I be able to move the shaft with finger pressure?
2. Shouldn't moving the control lever between OFF and Fast change the way the injection pump feels? They don't seem to connected except by a spring.
The ST doesn't seem to be designed to allow easy access to the governor as it appears that you have to remove the cover where the camshaft exits the engine. I don't mind doing this but if I'm just missing something simple I'll kick myself and move on.
Here's a pic:
and here's a direct link if I can't inbed pics:http://i66.photobucket.com/albums/h263/johnsbmw/IMAG0198.jpg
Thanks in advance for any and all help.
John....
