Gentlemen, not sure where to put this update, but this is as good as any the way I feel!
I think you know that the big end exploded when the engine ran dry in the dipper sump. It was not known why this happened, until now, I believe.
Remember that the piston was all gummed up and the rings were solid in their grooves?
Right, so I got the engine back together, and it fired first time yesterday. Great! Ran only for five minutes then retired.
Started the engine again this morning. Ran for about an hour, and basically stood there watching and listening. Nothing that exciting.
Then I remembered what someone on here said about maybe poor and porous castings might potentially let oil out.
So I took a closer look at the area below the engine - a nice little puddle of black................OIL!
Killed the engine straight away.
BUT, what did I find? A loose cam shaft end cover, that's what, with oil streaming down the outside of the casing. Oh dear, was this the thign that caused my loss of oil?
I cleaned everthing up , AGAIN!, and re-started, and no sign of oil in that place.
I'll be keeping an eye on this, but it could well be the cause of the problem.
I think perhaps the gummed up rings was a red herring. I don't suppose it should be happening, but it may well have nothing to do with the big end packing up.
Thanks for everyone's help on this subject.
Tim Eadie Mc.
