Author Topic: Lister CS crank gear timing mark  (Read 8488 times)
1958steveflying
« on: October 28, 2008, 11:29:30 AM »
Hi Everyone.
    My cs 5/1 was badly seized at every possible place so during dismantling i was unable to put timing marks where needed. Now i'm getting ready to rebuild i find that neither the old or new crank have a timing mark on them. Can anybody help with a good picture or accurate way of describing where it might be. The cam gear and idler gear have timing marks.
  Steve
SteveU.
Re: Lister CS crank gear timing mark
« Reply #1 on: October 28, 2008, 12:16:44 PM »
Hello,
I found this on Search under engine timing:
listerengine.com/smf/index.php?topic=1854.0
Good luck and have fun
SteveU.
1958steveflying
« Reply #2 on: October 28, 2008, 03:19:07 PM »
Thanks SteveU for the links however i was hoping to be able to assemble the crank and cam before the barrel/conrod/piston, and a close up pic of crank gear with mark on it would work wonders for me if anyone can help.
listerdiesel
« Reply #3 on: October 28, 2008, 08:45:29 PM »
Looking at the end of the crankshaft, with the keyways at 12 O'clock, the tooth gap in the 12 O'clock position is the one to the right of the right-most of the two marked teeth.
I have just checked two crankshafts, a 6/1 and my own 10/2 and they are both the same, with a small variation in position.
Peter
listerdiesel
« Reply #4 on: October 28, 2008, 08:58:50 PM »
The crankshafts from Lister don't have the pinions supplied separately, so if yours has been removed you need to retime it.
I have posted a picture here:
http://www.stationary-engine.co.uk/Misc/DSC09289.jpg
of the 10/2 crank gear. I should have marked the keyway centre as well, perhaps I'll pop back and do that and take the picture again:
http://www.stationary-engine.co.uk/Misc/DSC09292.jpg
The photographs are full-strength so you can blow them up on-screen.
Peter
« Last Edit: October 28, 2008, 09:11:40 PM by listerdiesel »
1958steveflying
« Reply #5 on: October 28, 2008, 11:06:59 PM »
Hi Peter,
  That is exactly what i needed and sorts the problem out for me perfectly. i appreciate the trouble you have gone too very much. ;)
  All the best Steve
lendusaquid
« Reply #6 on: October 28, 2008, 11:42:55 PM »
Just a side note. Originals are timed at bottom dead centre and i believe oids are done at top dead centre.This is the timing marks iam talking about,not the spill timing.
