Thanks for the replys. I will try to post a couple of pictures in a few days.
thanks also for the data Steve, mine has no COV, spacer shim under the cylinder, cast iron piston, flywheels with 2 oval cutouts and 1 round hole, engine mounted radiator, and fuel tank. also as i purchased the engine the head and cylinder were already removed due to a loose wrist pin that had scored the cylinder wall. the engine will need a complete rebuild, but as parts are available, this will be no problem.
the info on the fuel filter is in spanish, the person that i bought the engine from said that it had come out of mexico, so i guess it was an export engine?
the engine had beed painted over with blue paint, hopefully this can be easily removed to reveal the original green.
excellent forum! keep up the good work!
thanks, Ralph
