a simple test for the unbelievers in the group
take a clean piece of round stock and put in in a vice, stickin up or out don't matter
wrap your belt around it and hold both ends of the belt, pull back some tension and then try to seesaw it back and forth
get a feel for how much pull you have to put on it to start to bind up.
now turn the belt over on its back and repeat
no contest is there?
as an interesting addition to your library, go to your local bearing house, and ask for an old Browning catalog
they will usually give you last years book, which is about an inch and a half thick
in the catalog you will find sections on all types of drives and the engineering steps to take to build up a drive
with all manner of prime movers,, includeing single cylinder diesels!!
use their formula and do the math and you wont have any chirping at all
other manufactures have similar formula, folks like goodyear, martin, dodge etc
but the browning catalog is just easier to use and better explanations in my opinion
easier to follow anyway.
