I now feel proud to be a fully paid up member of the CS owning fraternity !! Today I travelled down to near Winchester from Worcester to collect my recently purchased Lister CS SOM. The engine was running upon my arrival and was a delightful sight and sound !! It is a totally original SOM unit , the seller purchased it from the farm where it had been installed from new. Consequently it has the original cooling tank , fuel tank etc. All the electrical control gear is intact and has never been tampered with. Even an original Lister exhaust pot is with it , which is VERY effective and weighs enough to need 2 people to lift !! It has had a top end overhaul , just rings and a valve regrind were required, the rings as more of a precaution. The bore & piston were almost indistinguishable from new apparently !! Cosmetically it has a very appealing patina with the original paint being in remarkably good condition. So , I shall just degrease and leave it as is.
So begins my CHP plant project !!
Pix will be taken as I unload next Tuesday , I will share those images with you then.
