Rob,
Re - staggered ring gaps. Forgot that one. As Stan says, but also some of your compression/power stroke gases will go that way too, and if the bottom end is unable to breathe it away adequately that too might be forcing more oil past that gap or helping to over-work the oil scraper ring.
I normally check/do these things 'as a matter of course' when putting things back together and it is easy to overlook some of the obvious possibilities for mishaps by the 'uninitiated' - when we are not quite sure of your ability/experience.
It is like your rod issue, if you have reversed things the big end bearing, for instance, will be experiencing a different wear pattern which will not be good for it. In all probability, it will not make any great difference, but the probability of there being extra/different wear was avoidable by re-assembing as nearly as it was previous to strip-down. I am assuming that you did not replace the bearing during the repair.
Regards, RAB
Regards, RAB
