Author Topic: Hello new to forum  (Read 3073 times)
Wally
Hello new to forum
« on: May 14, 2008, 03:34:37 PM »
I have had an interest in Listers for quite some time now and have acquired a Petter AB1 3000 rpm with generator , It came with the operators handbook , but no info on the generator .Near as I can tell its 50 hz 220v 3000w , I was wondering if anyone can id the generator? And if it was a package unit from Petter?
The brass plate shown below the rheostat is a warning about flash testing. The black frame and wheels were added later.
Thanks
Wally
[/img]
[/img]
« Last Edit: May 14, 2008, 06:16:17 PM by Wally »
rcavictim
Re: Hello new to forum
« Reply #1 on: May 15, 2008, 06:30:13 PM »
Welcome to the group Wally!  That is a kinda cute package.  The engine bears remarkable resemblance to the air cooled gasoline B&S engines of North American origin used on lawnmowers, etc.  I can't help with gen head data but perhaps someone here can.  Does it not have any activity?
-Changfa 1115
-Want Lister 6/1
    • Doug's Petteroid Stuff
« Reply #2 on: May 16, 2008, 01:21:38 AM »
I guess from the side it might pass for a letter series B&S engine.
I like the English electrical recepticals.
I'd be even more interested in the date of manufacture and wiring when the info starts to trickle in
Wally
« Reply #3 on: May 16, 2008, 04:04:07 AM »
I fired it up today , tested for voltage and got 12 vac with the rheostat half way .
  The story goes that this unit came from the engine room of a boat and was an auxiliary power for the battery charger.
It came to North America 30 plus years ago and has been in heated storage.
I changed the fluids and it started first pull, when the proper starting sequence was followed.
Wally
[/img]
[/img]
oliver90owner
« Reply #4 on: May 16, 2008, 07:29:11 AM »
Presumably the patch under the control box was where the rating/manufacturers plate was or is it still there?.  It might be hidden under the box mountings if it was an aftermarket union.  That little 4.5 HP engine will produce best part of 2.5kW but will overload on any more.
Regards, RAB
