On my way home from work day before yesterday saw this old lister by the side of the road. On checking on it I found that it had been partially submerged in salt water during one of the hurricanes ca 2000-2001, and just left and is now on its way to the dump. If I wanted it take it. But looking in such bad condition I passed on it. But by the next day, not being able to sleep that night thinking about i I drug it home. On opening the sump cover I found that it had not gotten any water on the interior and looked in good shape inside. I also pulled the head and found that the cylinder is also in great shape. All external components terrible.Â
The Injector had been removed but the hole wadded up with paper. I was wondering if anyone knew if a clone injector from an 81 would be the same to fit this? The model # 560VA13, 7.5 HP,
850 rpm. I will have to get all external components, fuel pump, governor linkage. Which should be the same as a normal 81, as I think everything remained the same on this except from the cylinder up.
Thanks for any ideas. Here's the link for photos
http://picasaweb.google.com/lindacjdd/ListerBAPhotos?authkey=zYw798mZkvk
