Author Topic: Blending used oils with modern diesels  (Read 33150 times)
westcoaster
Re: Blending used oils with modern diesels
« Reply #30 on: November 29, 2010, 04:44:31 AM »
Pictured under that BBQ is what I would consider a 20Lb propane tank...
Over here the tanks are filled by weight. One of those tanks takes 20Lbs in propane....
edit:
tank measures roughly 39 1/2" around the outside and 14" to the BOTTOM of the valve (this would be to the top of the tank not including valve or protective handle but sitting on it's stand)
« Last Edit: November 29, 2010, 04:53:44 AM by westcoaster »
