Author Topic: "Listeroid" 6/1 thru 28/2 Idler bolts  (Read 6693 times)
xyzer
« on: April 20, 2008, 07:42:08 AM »
Are the cam Idler bolts and dippers intechangable on all "listeroids"? I know most are but what about the big boys.
Thanks
Dave
Vidhata 6/1 portable
Power Solutions portable 6/1
Z482 KUBOTA
xyzer
Re: "Listeroid" 6/1 thru 28/2 Idler bolts
« Reply #1 on: April 22, 2008, 03:58:27 PM »
I can't believe no one knows the answer!..........I have a cambolt I want to sell to a 28/2 owner and we would like to have a clue if it will fit.
Thanks again
Dave
Z482 KUBOTA
« Reply #2 on: April 22, 2008, 06:01:54 PM »
Well if you sell it to him, you will then know for sure. By the way thanks for mine, it is working great!
JohnF13
    • woodnstuff
« Reply #3 on: April 22, 2008, 08:46:21 PM »
FWIW;
The idler bolt and idler gear on a 25/2 are the same as he 6/1 (at least it was on my Ashwamegh), I don't think the 28/2's will be any different.
John F
xyzer
« Reply #4 on: April 23, 2008, 05:23:47 AM »
John,
Thanks for the reply! I had no idea at all but assumed they did....assumed has got me into trouble before!
Dave
Z482 KUBOTA
oliver90owner
« Reply #5 on: April 23, 2008, 07:13:25 AM »
xyzer,
The answer to your original question was, of course, no.  The dippers on some are hollow.  I can not think of any reason why the cam drive gear should be any different on any of the range, but, with the Indian manufacture who knows!!
Regards, RAB
xyzer
« Reply #6 on: April 25, 2008, 03:10:52 AM »
Just to let you know the question has been officialy answered by JKson in an email to the owner and the answer is yes. I thought so but......I didn't want to bet on it. Thanks for the info guys!
Dave
Z482 KUBOTA
LincTex
  • Master Tinkerer
« Reply #7 on: June 12, 2008, 09:47:47 AM »
xyzer.....I need two cam bolts for the 6/1
Please PM me.
billswan
« Reply #8 on: June 12, 2008, 01:30:22 PM »
Yes xyzer could you please post more info or a link ? Cost?
xyzer
« Reply #9 on: June 12, 2008, 03:35:08 PM »
Please PM me.
Hollow dippers= $15.00ea
Offset Idlers  = $58.00ea (.035"-.045" offsets available)
Shipping included in US.
e-mail xyzer@aol.com
Dave
« Last Edit: June 12, 2008, 03:36:43 PM by xyzer »
Z482 KUBOTA
LincTex
  • Master Tinkerer
« Reply #10 on: June 12, 2008, 06:45:49 PM »
So you just rotate it so the eccentric takes up the excess backlash, then lock it down?
xyzer
« Reply #11 on: June 12, 2008, 07:30:38 PM »
Yes.....you have to balance the offset between the cam gear and the crank gear. The average "Listeroid" takes a .04" offset. The .035" is if a .04" is tight.....the .045" is if you think it could use more. Any offset other than tight will help the problem.
Dave
Z482 KUBOTA
