Bob,
Is the big end bearing shimmed? If so remove and check for tightness of bearing It should be tight on the crank without the shims, I would think. If it is still loose then you possibly have too much clearance on the big end.
I scraped in my bearing 'cos it had been run without a dipper (I think). I scraped it until just slightly tight with minimum shims and then shimmed for clearance. Spec says free but not more than 3 thou. Mine is certainly less than 3 thou and when it is worked with a vengeance, I will recheck and re-shim as necessary as this was my first scraping experience.
Things like did you check for ovality on the crank journal, come to mind. On mine the dipper threads prevent any temptation for the bearing inserts to move round. Other things to look at are timing and fuel type, along with injector operation.
Regards, RAB
